07-09-2015 10:55 PM
Hello, I'm having an issue with the aspect ratio in raw mode. I shoot both raw and jpeg I have set the aspect ratio to 16:9 which is how the jpeg is cpatured but the raw image is 4:3. What am I missing, how can I set the aspect ratio for both raw and jpeg to be 16:9 ? Thanks in advance 🙂
07-10-2015 09:40 PM - edited 07-10-2015 09:43 PM
The native aspect ratio for RAW files is 4:3 and cannot be changed. However, when you shoot both RAW and JPEG, there should be no issue when you go to process the RAW file. It should still recognize the aspect ratio you selected for the JPEG when you shoot both in RAW + JPEG. Perhaps the software you are using to process the RAW file does not recognize the aspect ratio and defaults to 4:3 only. I tried both the Canon software (Digital photography Professional) and Adobe Photoshop Elements and both had no problems with seeing the RAW as 16:9.
Steve M.
