Powershot XS620HS WiFi Connectivity
kkorotev
Is something I'm doing wrong or do I have to re-establish my WiFi connection everytime I turn the camera on?
Or, is there a way to automate this; Set it and forget it; Connects automatically???
Looking forward to good advice.
Kevin
Waddizzle
Kevin
That behavior may be by design.  If you are not actively using Wi-FI, then you will want to keep it disabled.  Having Wi-Fi active anytime the camera is turned on would probably drain battery power fairly quickly.
2 REPLIES 2
Waddizzle
Kevin
Thanks, Waddizzle,
I hadn't thought of that.  Makes sense now.
