07-18-2020 12:33 AM
I just bought this camera, and after doing normal setup, and finally turning it on, all I see is a blank white screen.
I can take photos and press buttons and hear sounds when doing so, but I can't see anything on the screen.
I tried googling around, but didn't see anything related to my issue.
Support is also closed for the weekend.....
Please help if you can!
07-18-2020 10:56 AM - edited 07-18-2020 10:59 AM
@BanjoThreeie87 wrote:
Samsung - EVO Plus 256GB microSDXC UHS-I Memory Card.
I'm using the adapter that came with it.
I'll try your method in a little bit here.
The micro-SD cards are highly NOT recommended. I have never used Samsung, just Lexar and mostly Sandisk. I do not have a card larger than 64 GB, either. I think 256 GB is probably way more than what that camera should use.
[EDIT] It sounds like the camera does not work, though. Get a refund.
07-18-2020 10:14 AM - edited 07-18-2020 10:16 AM
What brand / type of memory card are you using with the camera?
Remove the battery and card. Wait a minute. Now reinsert the battery. Turn the camera back on. What do you see?
Next move the selector dial between mode and set to Auto. Anything?
Press the > (Play) button on the back. Anything?
If not, call Canon or exchange the camera.
~CarePaks Are Worth It
07-18-2020 10:24 AM
07-18-2020 10:35 AM
