04-08-2020 11:11 AM
I'm trying to use the SX530 HS as a webcam. I have a Magewell USB Capture Plus converter and when I plug in the HDMI from the camera in the camera mode it displays no signal. If I am in the view photos mode it will display ok. How do I get it to display in the camera mode? I have ordered the USB mini B but have not received it. yet.
04-08-2020 11:57 AM
This has become quite a common question recently. The answer though is you can't use cameras as web cams.
04-08-2020 01:33 PM
@Nevets wrote:I'm trying to use the SX530 HS as a webcam. I have a Magewell USB Capture Plus converter and when I plug in the HDMI from the camera in the camera mode it displays no signal. If I am in the view photos mode it will display ok. How do I get it to display in the camera mode? I have ordered the USB mini B but have not received it. yet.
You cannot use your camera as a web cam via USB. The computer's OS sees a mass storage device, not a camera.
04-08-2020 03:39 PM
I am using a video capture device. You plug in the cameras HDMI output into the device and performs its magic and outputs a video input via usb3 to the computer. Then when you open skype or zoom and select The "USB Capture HDMI" the input from your camera is used as a webcam. It's pretty slick if you have the right DSLR. It's looking like I have the wrong camera but I want to make sure I'm not missing something.
There are numerous youtube videos on this subject. Just do a youtube for using your DSLR camera as a webcam with a capture device.
04-08-2020 04:24 PM - edited 04-08-2020 04:34 PM
"It's pretty slick if you have the right DSLR. It's looking like I have the wrong camera but I want to make sure I'm not missing something."
Yes, you may need a real DSLR.. If putting your camera into video mode does not provide what you need on the HDMI output, then you may have the wrong camera.
[EDIT]. But, even a DSLR is not the correct camera for use as a web cam. Dash cameras and camcorders work better. Even better, use an actual web cam.
08-31-2020 05:37 PM
Did you ever figure this out? I've watched a few of these videos and they look like you just plug it into the adapter and power it on and you're set, but I can only view pictures I've already taken, not use the camera as a video source.
09-09-2020 09:48 AM
I'm not sure if you found a solution to this yet. I have the same camera and was trying to do the same with my Elgato Capture device. After searching I found this artical --> https://www.techwalla.com/articles/how-to-make-a-canon-powershot-into-a-webcam Just mabe it works for you. I will try it when I get off of work. Lets compare notes.
10-03-2020 10:56 PM
Did your solution work? I am having the exact same problem. Any help would be appreciated.
10-26-2020 07:46 PM
10-26-2020 10:46 PM
