08-14-2016 09:03 PM
Hello, my canon G7x is fairly new, at first everything was fine but then this one issue came into existence. The screen will not come on after I press the power button, when I took it out the box the screen came on and everything was fine, just a message appeared saying no memory card detected. Now that I have inserted a memory card ( Sandisk Ultra Plus SDHC UHS-1 card) nothing comes up. Any help would be appreciated.
08-14-2016 10:02 PM
Press Menu button in lower right hand corner rear of camera.
08-14-2016 10:31 PM
Thanks for the reply, but I've pressed the menu button, held down on it, and spammed pressed it, but the screen just wont come on. The sound goes off indicationing it had been pressed, but no visuals.
08-14-2016 10:33 PM
Give Canon a call at 1-800-OK-CANON.
08-14-2016 11:05 PM
Will do, thanks
08-15-2016 05:15 PM
By all means yes call Canon since your camera is new and is under warranty.
I'm curious if you take the memory card back out will the display show that message again?
Also you can try taking out your battery and hold the power switch on for at least 30 seconds then insert the battery and try again.
I dont know how the memory card could effect the display but if you have one try another card too
