Reply
Occasional Contributor
Accepted Solution
Powering G7 X Mark III when used as USB webcam?
[ Edited ]
Question: Can the GX 7 Mark III be powered by something other than the battery when the USB-C port is connected to the computer as a webcam?
Setup:
  • Laptop has the EOS Webcam Utility installed.
  • GX 7 Mark III is connected via its USB-C port to a USB port on the laptop.
  • The Mark III is operating correctly as a webcam.
  • The Mark III cannot be powered using its USB-C port because that port is the video data interface.
Is there a product or way to power the Mark III so the battery does not run out?
Esteemed Contributor
Re: Powering G7 X Mark III when used as USB webcam?
Canon AC Adapter Kit ACK-DC110 | Canon Online Store|Canon Online Store
Compatibility
-- Refurbished PowerShot G5 X Mark II
-- Refurbished PowerShot G7 X Mark III Black
-- PowerShot G5 X Mark II
-- PowerShot G7 X Refurbished
-- PowerShot G7 X Mark II Video Creator Camera Kit
-- PowerShot G9 X Mark II Black
-- PowerShot G9 X Mark II Silver
-- PowerShot G7 X Mark III Black
-- Refurbished PowerShot SX740 HS Black
-- Refurbished PowerShot SX740 HS Silver
-- PowerShot G7 X
-- Refurbished PowerShot G9 X Mark II Black
-- PowerShot G9 X Black
-- Refurbished PowerShot G9 X Mark II Silver
-- PowerShot G9 X Silver
-- PowerShot SX740 HS Black
-- PowerShot SX740 HS Silver
-- PowerShot G5 X
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~imageClass MF644Cdw
Thank you for the reference. I rejected that solution earlier in my research because it appears to require that the battery compartment door remain open while this adapter is in use. I guess that is the trade off in order to power the camera.
I ordered this power adapter setup: https://www.amazon.com/dp/B074KCB6TS
Now to figure out how to have a stable mount for the camera while the battery door is open. The door and the mount point are very close together.
Respected Contributor
The battery door will close, as usual, there is a little flap on the battery compartment that folds open for the cable to pass through it and allows the camera to mount flush
I saw that flap in review videos of the Mark II. The Mark III does not have that little flap.
[ Edited ]
The camera will not turn on unless the battery door is closed....here is a list of compatibility for that adapter off the Canon website and I do not see the Mark III:
-- Refurbished PowerShot G7 X Mark III, Black
-- PowerShot G7 X
-- Refurbished PowerShot G9 X Mark II, Black
-- PowerShot G5 X
It is there. Highlighted in red
-- PowerShot G7 X
-- PowerShot G5 X
I didn't note this comment before. That is a concern!
Ahhh oh yes I see it. Still, I do not see how it will work if you cannot close the battery door? The manual mentions a USB Power Adapter PD-E1
powered by Lithium
