Reply
Highlighted
New Contributor
Power shot sx530 hs question
I take 200-300 pictures a day but something is different and I'm not sure what setting I changed. When I review my picture there is a frame around the screen that wasn't there before. And when I put on computer the picture is smaller. Any help would be appreciated.
Highlighted
Super Contributor
Re: Power shot sx530 hs question
Select the photo that has a frame in a  playback mode.
Press DISP to display the data of that photo to determine your settings on this photo.
Things to look at;   cropping to resize the photo,  if this is a saved copy from original photo - you can delete it, frame maybe a gridlines unless you set up the frame added effect ? size of display area is small ?( see menu ).
Highlighted
New Contributor
Thanks. I went back and reviewed pics like you said and there is a difference but I'm not sure how to fix it. The older pics have an M2 in bottom left corner and the new pics have an L in the bottom left. It looks like maybe it's set on landscape but I'm not sure how to fix it. Any help would be appreciated.
Highlighted
Super Contributor
M2 size is 3.5 x 5 in. or postcard size, L is 16.5 x 23.4 in. ( default size ). The L has bigger resolution.
You can rotate the photo in playback mode, ( press menu and arrow down to select rotate ) and save another copy. You can delete the unwanted original photo.
powered by Lithium
