11-28-2012 11:04 AM
11-28-2012 10:15 PM
Did you remove the battery imediately? Was the camera powered on at the time? One thing you could try is removing the battery and card, soak the camera in distilled water, and then put the camera in an oven at just over 100* for a few hours. Granted if you didn't take the battery out right away the camera is likely to be NFG. Sorry.
12-05-2012 05:45 PM
Hi Mkirby207,
I'm sorry to hear that your PowerShot S95 fell into the water.
Unfortunately, your camera will require service to correct this issue.
To set up service, please go to canonusa.com/repair.
Once there, enter your model number, the date of purchase and your Zip Code, then click "Submit" to set up your repair.
