11-22-2015 08:38 AM - edited 11-22-2015 08:50 AM
I have all the sounds in maximum from the menu but still no beep when focusing as the manual says. The camera is brand new
11-22-2015 10:46 AM
I think it will only beep when in Tracking AF mode, see if that works or have you already?
11-22-2015 12:29 PM
I've done it and it doesn't beep. Furthermore the manual says it should beep (twice) when focusing in every mode.
11-22-2015 01:33 PM
Ok well since its new you can call Canon direct and they can help you. I looked thru your manual for a cause and I just looked again and searched for the word "beep" and your right it should beep for a few functions the only other thing I saw is maybe you have the mute turned on but I bet you checked that too.
11-22-2015 04:43 PM
First of all thank you so much John for trying to help. As you imagined my camera was not on mute. How do you think I should contact Canon about it?
11-22-2015 04:56 PM
Heres their number best of luck to you they are pretty helpful 1 800 652-2666 Monday-Friday 10:00 am to 10:00 pm
