02-17-2019 07:11 PM
02-21-2019 09:36 AM
Hello jaysmoon,
The PowerShot SX530 HS can have up to 3 Wi-Fi connection settings saved at a time. When you need to free up a connection spot for a new one, the "Edit a Device" option in the "Select a Device" Wi-Fi screen should be used.
After selecting which of the 3 saved connections you want to remove by highlighting it and pressing the Func./Set button, choose the "Erase Connection info..." option to remove those settings, which will free up that spot.
These steps can be seen on pages 122-123 of the camera's manual HERE.
If you encounter an issue with these steps please call 1-800-828-4040 to reach our friendly Technical Support Team. They can walk you through the process of removing one of the saved connections on your SX530 in real time to ensure the process is successful.
02-21-2019 09:36 AM
Hello jaysmoon,
