Reply
New Contributor
Accepted Solution
LCD screen not working on new SX70 HS
I received this camera as a gift & tried it out today for the first time. I can not get the LCD screen to turn on. The viewfinder works fine. I've read the manual, as well as previous posts on this forum & have tried 'Reset Camera', adjusting the Display Control from Auto to Manual, hitting the Quick Control button several times....and nothing, just a black screen.
I'm hoping someone will be able to 'enlighten' me.
Thanks!
VIP
Re: LCD screen not working on new SX70 HS
Thanks!
If you can access the menus and are able to "Reset Camera" back to factory defaults, that tells me the LCD screen is probably working just fine, and your problem is elsewhere.  Make sure hat you have removed the lens cap.  If removing the lens cap does not produce a screen image, then I suggest that you contact Canon Support for your area.
New Contributor
Thank you for your prompt response. Yes, the lens cap is off. I'll give Canon a call on Monday!
Have a great weekend!
New Contributor
Just a follow up. I contacted Canon via phone, then drove to their service center in Irvine, CA. After inspection, they decided they could not fix the issue with the monitor & will be sending me a new camera.
New Contributor
Powershot SX70 in low light conditions works poorly
If I use auto seting on an overcast or cloudy day, the photos are blurry, fuzzy, dark, and not in focus. This is a refurbished camera, sent to me by Canon after my first SX70 was returned due to the zoom lens freezing. I have had this one only maybe 6 months, and it seems to be geting worse. Bright sunny days, fine...but if not, the photos are crap.canon 2.jpg
VIP
Re: Powershot SX70 in low light conditions works poorly
Looks pretty normal to me.  The camera has an ISO that tops out at 3200 and a maximum aperture of around 3.5(?).  Odds are the shutter is pretty slow, which means what you are seeing could be camera shake.
What is the shutter speed and zoom setting in mm?
I suggest that you use a tripod, or set the camera on a stable surface and take some shots.  The "problem" wil never completely go away, but your shots should look noticeably better.
New Contributor
Thanks...I use "nature's tripods", but I am going to fool around iwth different settings. I just hope it is not one of the auto-focus issues described by others in this forum.( most of my pics are taken while canoeing, so I can't mess around too much with changing settings as the canoe bobs in the wind!)
powered by Lithium
