07-21-2018 07:36 PM
I just bought this camera, I have added filters to it. I have an adapter on it for 58mm with uv filter lens. I started taking taking pictures and some of my pictures not all in the upper right and left corners there is a black triangle. I don't understand if it is a setting I have because it is not on all the pictures. Can someone please help me with this issue.
Thank you.
07-22-2018 05:46 PM
@PunkyPal wrote:I just bought this camera, I have added filters to it. I have an adapter on it for 58mm with uv filter lens. I started taking taking pictures and some of my pictures not all in the upper right and left corners there is a black triangle. I don't understand if it is a setting I have because it is not on all the pictures. Can someone please help me with this issue.
Thank you.
Remove the filters, and see if the problem goes away.
You really do not need a UV filter. Nearly every digital camera has light filters built into the sensor assembly, including UV.
07-22-2018 07:08 PM
Thank you for your help.
07-22-2018 08:30 PM
I think it might have to do with the adapter going from 67mm down to 58mm and the zoom setting you may have had it on
07-23-2018 05:02 PM
Hi PunkyPal,
Thanks for posting.
If you're using the optional Filter Adapter FA-DC67A, I recommend the use of a 67mm filter. The use of a smaller filter is probably causing the issue that you've encountered.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
