04-15-2020 10:53 AM
I appreciate your problem. You are stuck with cleaning up someone else's mess.
Good luck.
04-15-2020 11:36 AM
On Wednesday, April 15, 2020, Canon Inc. will be releasing firmware ver. 1.1.0.0 for the PowerShot SX530 HS. Download it here https://Canon.us/ltvsb
Firmware Version 1.1.0.0 incorporates the following fixes and enhancements:
Note: This is a required firmware update in order to enable the use of this service.
04-15-2020 12:25 PM
Thanks!! the firmware update fixed the problem both cameras are connecting again
04-15-2020 12:52 PM
04-15-2020 12:53 PM
Once I deleted my WiFi settings and reconnected, I think I have the new image.canon downloader work.
Thanks, Canon, for resolving the issues.
don
04-15-2020 12:56 PM
Same here with the 510 HS, need a soluition
04-16-2020 08:49 PM
Same here, but mine is a PowerShot SX60. I can no longer connect to my wireless since the old site went down. I get the same error message "set correct date/time". The correct date/time are, in fact, set. And yes, the correct time zone is also set on the camera - I checked that, as well. The only free way to find an answer to this is here. Any ideas?
04-16-2020 08:50 PM
Isn't there are charge for this so-called service?
04-16-2020 08:51 PM
I could not agree more. I've loved the camera and use it almost daily. This issue with my PowerShot SX60 did not happen until the new image website went up. I am thoroughly disgusted with Canon at this time.
04-16-2020 08:53 PM
