05-04-2019 07:36 PM
Hi, all! I am having a problem getting my new 2018 Mac Air to recognize my old Powershot SX40 HS. Is there any software/update I need to download to get it to work? Thanks for your help!
05-07-2019 04:47 PM
How are you connecting it? Did you try Image Capture (in your apps folder) directly?
05-07-2019 04:47 PM
05-07-2019 09:31 PM
I connected it to my Mac Air adapter (there are no USB ports in the laptop). I just ordered a card adapter, so I can insert the card directly in. I hope it works! Thanks for your help. 🙂
09-08-2019 06:10 PM - edited 09-08-2019 06:12 PM
kvbarkley: Thank you SO much! This is the BEST solution and the easiest.
07-02-2019 04:01 PM
Hi Ilfod1982,
Thanks for posting.
With the camera connected to your computer via a USB cable, when you power the camera on in the playback mode, your camera should recognize it the camera as a "PowerShot SX40 HS".
If this doesn't occur, or you're still encountering difficulty, please contact our toll-free technical Support Department for assistance. They'll have the advantage of being able to guide you through the connection process, while following along with the camera on their side.
You may reach our Technical Support Department by calling 800-OK-CANON (652-2666), Monday - Friday 9:00 A.M. - 9:00 P.M. ET (excluding holidays).
09-08-2019 06:15 PM
Thanks, Richard! I found the Image Capture solution to be the easiest. Maybe you can help me decide which newer Powershot camera to get... I want it to have WiFi capabilities and a better zoom, along with Image stabiliozation.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
