10-12-2015 08:10 PM
I have tried using my manual to register my camera and even got support help and I still can't get a connection after following the instructions(to get photos into computer) The support guy told me that there there is a compact flash reader device that can connect my camera to my computer(since I did that with my old Canon S70.) I need to get this device as the old one I have is not compatible with my new camera.
10-12-2015 08:23 PM
What model camera do you have now, still a S70 ?
10-12-2015 11:00 PM
I have the Power Shot SX710HS.
10-12-2015 11:27 PM
I don't think you've worded the question correctly but it sounds like you want to buy a card reader, which is a device you insert your memory card into & connect to your computer via a USB cable. Just about any currently sold card reader (they are relatively cheap) should be up to the task.
10-13-2015 01:08 PM
I have a USB device that I used for my old camera and wondered if this usb device will work for this new memory card. I also learned that my comuter is not set up for wi-fi connections with other devices(so my husband told me) He is out of town and said that he could get it set up on his return. Which is easiest to do? I would prefer doing the old method that I did with my old camera.
10-13-2015 01:44 PM
I would say at the very least try the USB reader you have until your husband gets back to help set up a wifi direct connection.
