01-31-2018 09:00 PM
01-31-2018 09:13 PM
Hi and welcome...nice camera! I think there should be a ring that goes around that dial that turns and not the dial itself
01-31-2018 09:18 PM
01-31-2018 09:28 PM
Your welcome! There is a circuit board under that ring that reacts to it turning and makes the changes. If it's not some weird setting then I suspect either the ring and/or that circuit board have failed. You did a reset to defaults and the other one where you remove the battery and press the on button for at least 30 seconds then replace battery and retry?
01-31-2018 09:41 PM
