12-30-2015 10:46 PM
I have a Powershot SX530 HS. I have no issues connecting it to my wireless network and seeing my PC but I can't connect to my PC. I can see the camera show up on our home network while it tries to connect but it times out after about a minute and the camera says "Connection failed". I have run the Wi-Fi Connection Setup software on my Windows 10 PC.
Any ideas how to resolve this?
12-31-2015 12:28 PM
@Jamz58 wrote:I have a Powershot SX530 HS. I have no issues connecting it to my wireless network and seeing my PC but I can't connect to my PC. I can see the camera show up on our home network while it tries to connect but it times out after about a minute and the camera says "Connection failed". I have run the Wi-Fi Connection Setup software on my Windows 10 PC.
It sounds as though you're saying that both the computer and the camera are wi-fi clients and are trying to contact each other through a previously existing access point that serves your home network. Is that the case, and is it what both the camera nnd the computer expect? What is the "Wi-Fi Connection Setup software" that's now on your PC? (I assume that when you say you've "run" it, you mean that you've "installed" it.) What security protocol does your wi-fi network use, and are you sure the camera is set up to use it correctly?
To put it another way: Have you set up the connection between the camera and the computer exactly as your instruction manual suggests, or are you assuming that all wi-fi networks are similar and that the camera will automatically know its place? You can ignore these questions if you're really knowledgeable about wi-fi, but I have to tell you that a lot of people who think they are, aren't.
12-31-2015 06:11 PM
I thought I was pretty clear that connecting to Wi-Fi was not an issue.
Thanks, but I figured it out and am connected. Case closed.
01-07-2016 10:57 PM
Jamz58
I am having the same issue, would you share how you solved? Thanks
01-08-2016 05:22 PM - edited 01-08-2016 05:23 PM
Sure Frenchfrey,
I simply missed a step in the instructions. If you have the same eaxact model, see step 9 on page 108 of the manual. The camera is actually waiting for you add the device through the Windows Control Panel.
It was that simple for me. I hope that helps.
01-09-2016 11:39 PM - edited 01-09-2016 11:40 PM
You may want to try disabling your antivirus or firewall. The Avast firewall that I am just demoing blocked the camera from connecting.
01-10-2016 11:59 PM
12-30-2016 02:25 PM
I joined this communityy just to help anyone who has bought the Powershot Sx530 . Try as I might I couldn't connect it to my mac with wifi. Then I looked at the Cannon online store and they sell an interface cable IFC-400PC . it says that it is included with many of their cameras and NOT included with many other models . I easly checked what cameras it was capatible with on the store site and the SX530 is one of them . It's a $12 item with 2 day free shipping !!! The cable plugs into USB port on computer and the A/V out Digital port on the camera . Works like a charm or like all my other digital cameras. Why they don't mention this in the manuals or PDFs I can't imagine ??? They could sell another part and save people countless aggrivating hours trying to hook up thru wifi . Another easy way to make it work is to just take out memory card and put it in a a card reader . Later year Macs all have card readers .
Have a Wonderful 2017 !!
Nancy
04-09-2017 04:12 PM
does that cable llow you to view live feed off your camera onto your computer screen???!
04-15-2017 12:41 AM
I am trying to connect my new SX530 HS to my laptop PC via the home wifi. The camera successfully connects to the wifi and finds/displays a few devices on the wifi network, but not my laptop? My laptop is running Windows 10. Any ideas?
