The camera is fine. At 50X hand held the pictures are clear and sharp. The problem is that the Wi-Fi will not connect to a computer running Windows 10 so it is already obsolete. I had no problem connecting to my wife's computer running Windows 7.
03-28-2016 07:23 PM
Can I use the PowerShot SX530hs camera with Windows 10??
03-29-2016 10:55 PM - edited 03-29-2016 10:56 PM
If you're asking whether Win 10 will recognize the camera if hooked up by the USB cable I don't know the answer but if you only do that to download your photos all you can do is try it. IF however you want to control the camera from your computer you better hope for a more reliable answer than this. When you can't download via the USB cable a memory card reader is your friend. They work with just about any computer operating system as long as the computer has a USB port.
03-29-2016 11:22 PM
Your best bet is to call Canon and ask them. I did see 1 review on the Canon website which suggests it is not compatable with windows 10.
