03-04-2014 05:31 PM
03-09-2014 08:54 AM
Hi spetho2001!
Thanks for posting to the forum.
The camera does support SD, SDHC and SDXC cards that are Class 10 rated, so the cards should work. However, keep in mind we have not tested specific cards with the camera, so we cannot say for sure or recommend which specific cards to use.
This didn't answer your question? Find more help at Contact Us.
03-10-2014 09:44 PM
This did not answer my question. I get the same no answer from contact us. Very poor service or research for these cameras. The list of cards that work is not much help either.
Thanks anyway,
TomS
03-10-2014 09:46 PM
Can't believe it! A card does not come with the camera and the company that makes the camera can not recommend a card!
03-11-2014 09:44 AM
03-11-2014 08:21 PM
smack53,
I found what you said hard to believe. The camera will not work without a card. You might as well throw it out. So, like I said, I found it hard to believe that the maker of a camera, that needs the card to work, can not recommend a card. I happen to own a Nikon CoolPix S8000 so I pulled out the user manual and there on page 149 under "approved memory cards" was a recommendation for four manufactures of SD cards and the specs for those cards.
