06-27-2013 10:00 AM
I recently purchased a PowerShot SX260HS in order to take good pictures for an upcoming vacation. However, I am unable to figure out a good setting to avoid blurry pictures of moving objects! If it is not already apparent, I am a complete moron when it comes to technology! Any suggestions (besides staying away from photography), would be appreciated!
06-27-2013 10:08 AM
You need to understand a few simple rules for action starting with the fact you need a fast shutter speed & good panning skills (which comes with practice. Best way to do it is by using the Tv mode (Time value or shutter speed mode) or you can cheat a bit & use Sport mode but that isn't as reliable. A lot of the info here relates to action photography especially the things you want to learn control wise & note that unless your manual specifically says you can use IS for panning TURN IT OFF.
http://www.rccanada.ca/rccforum/showthread.php?t=147971
06-30-2013 12:51 AM
Agreed, like anything in photography it helps if you practice, practice, practice. That's the beauty of the digital age, you can practice like crazy and not waste film doing it.
07-17-2013 01:22 PM
Thanks so much for the advice! Sorry it took me so long to respond. I shall begin practicing immediately!
