03-04-2015 09:39 PM
I had been using the AUTO setting for flash and was very happy with the results. All of a suddon--the flash will not work with any setting. Any thoughts, should I take it to a camera shop, sent it to Canon, or what?
03-05-2015 03:37 PM - edited 03-05-2015 03:38 PM
You might have turned off the flash function. On the back there is a lighting bolt symbol on that cross above the fucntion set button number 13. Press it then you should see 3 options for your flash, on, off or auto. Check yours is on Auto.
03-06-2015 04:16 PM
It is set on Auto. As I said in my original submission--it will not flash on any setting.
Thanks
03-06-2015 05:00 PM
And you do not get any error codes ? no Flash with a line thru it icon on your LCD ?
Have you tried a "Reset ALL" or "Reset Defaults" thru your setting menu just as a last resort?
Also the flash depends heavily on the battery to charge up the capacitor, much more so than to just take a picture. Do you have more than one battery to try or buy a new one ? Usually though a failure to charge the flash will produce an error of some sort yet a new battery is cheap to try and you will use it once the camera is fixed unless your going to trash it or sell on an auciton site listing the problem in the ad
If none of the above helps I would suggest especially if your camera is still under warranty to call Canon since as you say every setting kind of covers all the bases.
Just trying to throw some ideas out there, you'd be surprised at how many times its just a simple setting or some obscure sequence of buttons that may have accidentally gotten pushed and created a problem.
03-07-2015 06:57 PM
The A590 is from 2008, so it might be that the flash bulb needs to be replaced. Do you use the flash a lot? It could also be that the flash compensation is set very low and you're not noticing the flash. Press the func/set button and scroll down to the +/- ans see if the flash compensation is down on the low setting. If so, set it higher and see if that helps. Otherwise, I'd be thinking the flash bulb.
Steve M.
03-10-2015 01:43 PM
03-10-2015 03:00 PM
Unfortunately he is telling the truth. That camera is not worth that much on the used market, and unless you're willing to open up the camera, the labor rate will bring the cost up significantly. I'm not sure where you could even buy the flash bulb either. These cameras are not really made to be repaired since everything is on circuit boards, which are costly in themselves.
KEH Camera is an on line shop that I've purchased camera gear from and they have a large assortment of used cameras that could replace the A590. I checked before, but they did not have any used A590's available at this time.
Steve M.
03-10-2015 03:00 PM
those can be bought used and in working order for 50-80 dollars on an auction site so yes and service will cost more than the camera is worth. If you have a lot of accessories and things for that model and want to stay with it you could go that route.
