06-07-2013 04:05 PM
sports setting on my SX50HS worked initially but now the pictures are so bright, only an outline of the subject can be seen. Don't recall making any changes to settings.
06-10-2013 12:53 PM
06-07-2013 05:35 PM
Using your manual check to see if you've accidently added some POSITIVE Exposure Compensation If you havent can you add some negative EC to get a correct exposure?
06-10-2013 12:53 PM
That was it - thanks!
06-10-2013 08:28 PM
Good to hear it's fixed. Now that you know about Exposure Compensation learn to use it when basic setting aren't quite getting it right. EC is your friend.
