07-24-2020 12:40 AM - edited 07-24-2020 12:50 AM
My Macbook Pro does not recognize my SX740HS. I'm able to transfer/upload photos but macbook pro (catalina) does not recognize the camera and is therefore unable to charge the battery. I purchased Canon IFC-600PCU from Canon directly.
07-24-2020 01:34 PM
Canon camera batteries do not charge via USB. You must use the supplied charger. Your manual says as much.
07-24-2020 01:57 PM
This is not necessarily true! Canon sells the IFC-600PCU that I purchased after speaking to a sales representative, to allow one to charge the battery while connected to a computer. Furthermore, I was able to charge the battery fully on my PC (so much for the manual saying as much), but I would like to do so on my Macbook Pro because I used it frequentely to travel.
07-24-2020 02:32 PM
That is just a Canon branded USB cable. It should work on the Mac as it would on the PC. Now if you only have USB-C connections on the Pro, you might need Apple's USB-C to USB dongle.
While the camera can be powered via the USB for downloading, I don't think it charges the battery.
07-24-2020 03:13 PM
Hello, I hear you that it should work on both the PC and the Mac, but it does not. I have all of the necessary cables you mentioned and have been connecting them correctly; while it works on the PC, it does not on my Macbook Pro. I don't need to power the camera for downloading photos, I do so wirelessly. I'm including a picture here to demonstrate that the battery does charge via the USB. The battery was completely dead, I connected the camera to my PC after responding to your first message and now there are two bars and I can turn on the camera.
07-24-2020 03:15 PM - edited 07-24-2020 03:18 PM
No problem. Just saw your follow-up message. I was trying to attach the photo to confirm that the battery can be charged via cable, but having some difficuty doing so.
07-24-2020 03:16 PM
Have you tried running image capture directly to see if it can see the camera?
No, how do I do that? Will google or consult manual in the meantime.
07-24-2020 02:37 PM
I stand corrected, it appears you can charge the battery via USB. However, even if the Mac does not recognise the camera, it should still charge.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
