08-29-2024 09:05 PM
I have upgraded my laptop hard drive and now when I try to connect my SX720 HS via wifi to my laptop again it connects but not long enough to download the pictures from the camera. After a couple seconds, the camera disconnects from the laptop. My laptop is running Windows 10 Home edition.
10-19-2024 08:57 PM
Hi jcmadlung,
Is your camera battery fully charged? Try it again with a battery that is 100% charged.
10-19-2024 10:38 PM
Hi and welcome to the forum:
You can save yourself a lot of hassle and work more efficiently if you do the following, using either a built-in or USB-connected SD card reader.
Follow this procedure - it is the fastest and more reliable method and requires no software:
10-20-2024 11:33 AM
I do not recommend using Wi-Fi to transfer photos from your camera to a laptop. For one, it is prohibitively slow, and the slow transfer speeds means an increased opportunity for RF interference to corrupt data.’
Using a USB cable is at least 10x faster, probably closer to 100x faster. Or, remove the memory card and use a card reader connected to your laptop.
