05-01-2013 07:10 PM - edited 05-05-2013 10:54 AM
UPDATED May 5:
I apologize to the forum for mixing two different problems. They are unrelated.
Problem #1: User error. I thought I was using a class 6 SD card but I was wrong. The yellow "!" indicates a pathologically slow card. Upgrading to a class 10 resolved this problem.
Problem #2: UNRESOLVED. Red battery indicator comes on prematurely. On a fresh charge, it'll turn red after recording for a couple of minutes. On a partially drained battery, it turns red immediately upon entering movie mode or pressing the record button. Turn the camera off and then right back on in "still" mode and it shows full charge and works fine ... until trying to shoot video. I have not precisely measured recording times but it'll record for at least 20 (maybe 30?) minutes while flashing red.
01-16-2015 04:36 PM
01-16-2015 05:44 PM
From Wikipedia, "The very word "Edsel" became a popular symbol for failure."
01-16-2015 05:59 PM
01-17-2015 07:03 AM
I guess there must be much younger people reading and not knowing what "edsel" was! Forgive me. I forget other people in the world are not old as dirt like me.
01-17-2015 07:15 AM
01-17-2015 07:59 AM
It is an expression referred to many times in the USA. A blip in history. I'm 83 !
01-17-2015 12:42 AM
@QualityPictures wrote:My camera is the same as yours, but my whole family uses this camera. So taking away the battery level indication in the camera would cause frustration and missed photo and video opertunities. Also the worry of charging, as sometimes a battery can be left in the charger for weeks. I'd have to run some tests to see if just the full charge light is affected or whether the battery can end up being over charged, with the tape on.
Just remove the tape before you put it in the charger.
01-17-2015 04:49 AM
11-15-2013 05:12 PM
Hi everyone, to keep you and your gear safe we don't recommend do-it-yourself modifications, such as covering the middle pin with tape. In fact, doing this will interrupt important circuits that could cause unsafe conditions, such as overheating. We strongly advise against modifying the battery in any way.
11-15-2013 05:19 PM
Jason. Your suggestion,
Is funny. People would not resort to trying such fixes if Canon would truly own up AND FIX the issues that this camera has.
