07-31-2021 09:15 PM
Experienced user. 3 hours of work. The camera is on the wifi network. The wifi connection setup has been installed and run on the pc. Cannot find the camera while attempting to add a new device on the PC. The camera searches forever for the computer. Both are on the same wifi network. It works with NFC to a smartphone, wifi to a smartphone. The PC can find the camera when the camera has its own wifi node.
It would seem to be a fault with the PC software. I'm running Canon EOS utilities also for another camera.
08-01-2021 08:25 AM
07-31-2021 09:43 PM
One more thing. Sometimes, it just prompts me to set the correct date and time. I already set the date and time.
This is an all-day project. Frustrating!
07-31-2021 09:44 PM
Also - I killed the EOS app. No change.
08-01-2021 01:06 AM
Hi there,
Based on what you describe this could have to do with access restrictions on the network, but security settings on the PC might also have an effect. If possible one thing you can try is a different PC on a different network or even the same PC on a different network to see if there is a change.
08-01-2021 08:25 AM
