01-13-2023
10:44 PM
08:24 AM
How can I delete pictures from my A530 without deleting them from the folders I made for those pictures?
01-15-2023 01:34 PM
Are you using the EOS Utility to download image files from the camera? Another method to download image files is to remove the card from the camera, and use a card reader with your computer.
It almost sounds like the camera is still connected when you are using the computer to delete files from the camera. I’m surprised that it would allow you to do that, so something else must be happening.
If you are not using a card reader, then you should disconnect the camera prior to deleting files in the camera or reformatting the memory card.
01-15-2023 02:07 PM
You certainly CAN delete files from the camera while it is connected to the computer. I do it. What's the surprise?
01-15-2023 03:11 PM
@normadel wrote:You certainly CAN delete files from the camera while it is connected to the computer. I do it. What's the surprise?
The memory card in the camera has always been “read only” from the computer. I suppose of the EOS Utility Launcher Service is stopped, then maybe you can R/W the memory card in the camera.
01-15-2023 03:26 PM
My experience is that the memory card, from the computer, has never been read-only. At least as far as being able to delete files.
01-15-2023 04:21 PM
Unless the OP provides the details, it's all guess-work. We have no idea what software is being used to copy/sync the photos. We don't know the computer, OS, etc.
01-16-2023 01:26 AM
Did you not read the question?
01-16-2023 08:40 AM
Can you see the images on the computer if the camera is not plugged in?
The only way this could happen is if you are seeing the file system on the camera, not the filesystem on the computer and you never actually downloaded the images. But I have never seen a Canon work this way.
01-16-2023 08:42 AM - edited 01-16-2023 08:44 AM
@tuxedo wrote:Did you not read the question?
”How can I delete pictures from my A530 without deleting them from the folders I made for those pictures.”
Like I said, disconnect the camera from the computer and reformat the memory card in the camera.
But, be sure to first confirm that the image files were safely copied to your computer. Once you reformat the memory card, they may be gone forever.
