02-28-2016 10:55 AM
I lift the flash on my Powershot SX50 HS, but the flash doesn't go off. Could I have accidentally turned it off?
02-28-2016 12:16 PM
Yes check in the settings menu for the flash settings it might be off and if you do not have any custom setups stored you can do a reset all to defaults in the settings too which will also turn the flash back on.
03-02-2016 10:12 AM - edited 03-02-2016 11:43 PM
Hello,
Beyond checking the flash settings, if your SX50 happened to be supplied with a hot shoe cover for the EXTERNAL flash then I believe the cover must be removed in order for the INTERNAL flash to operate.
Just a thought!
Tony
