How to reset to default in sx60hs? The instructions in the manual do not work.
jollywolly2
  When following the instructions in the manual  the reset button is grayed out.  Also the LED screen only works for replay but not for taking pictures.   I'm sure most of the problems are operator caused and I think reset to default will help me start over. Thanks for any help.
2 ACCEPTED SOLUTIONS
John_
Press the down arrow several times till the LCD turns on :
See if you can do a reset all through your setting menu at that point. If not remove your battery and hold the power switch on for at least 30 seconds then insert the battery and try again.
 Also try the reset all when in Auto shooting mode first and be sure you havent selected the WiFi reset all.
John-
thanks- that did it.
5 REPLIES 5
John_
John-
Ok great thats an awesome camera !
Thank you so much, solved in 5 seconds 🙂
Non riesco a resettare la mia Canon SX60HS ai valori iniziali.Le istruzioni sul manuale non nhanno effetto.Chi mi sa aiutare ??
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
