02-11-2024
10:58 AM
08:48 AM
I just opened the box for my new Canon PowerShot G7X Mark III Digital Camera and am learning how it works. One thing I'm not seeing in the manual is how to download images taken with this PowerShot to my desktop computer. I am not a smart phone person and am not interested in becoming one. Also, I have vision issues, so I edit my photos on a *huge* desktop monitor.
My previous Canon PowerShot camera, vintage 2010, enabled this transfer via a USB cable that physically connected that camera to a computer. I don't see (at least so far) a place to plug a cable into the G7X Mark III. None came in its box either.
02-11-2024 11:57 AM - edited 02-11-2024 12:02 PM
I just checked the specs for your computer and it apparently HAS a built-in SD card reader. In the image below it is likely the vertical slot to the left of the audio out port: NOTE the card will fit comfortably only one way, so if it does not fit, rotate the card 180deg and try again
02-11-2024 11:25 AM
These days, it will be much easier to work with a card reader. What computer are you using? Some computers have built-in card readers.
If not, card readers are fairly inexpensive. Be sure to get one that can attach to your computer. If you provide the exact model of the computer you're using, we can help ensure you'd get a correct item.
02-11-2024 11:25 AM - edited 02-11-2024 11:27 AM
Hi Dan and welcome to the forum:
The recommended, fastest and most reliable method is to do the following:
1. Turn off the camera
2. Remove the card from the camera and place it in a SD card reader attached to your computer (either built-in or via a USB cable)
3. When it is recognized, the card will be displayed in your file manager as a conventional removable drive, so copy the files from the card to your computer as you would normally do, and check that they have been copied.
4. If using a PC, use the windows Eject feature (place the mouse over the icon for the card, right-click and select Eject). When so advised, remove the card from the card reader
5. Place the card back in the camera again, and turn it on
6. Use the camera's Format command to format the card clean, ready for more shooting - do not use the Delete function, this can lead to card errors eventually.
02-11-2024 11:45 AM
Thanks for the speedy reply, Ricky. My desktop computer is a Dell Inspiron 3880.
02-11-2024 11:50 AM
Thanks for the speedy, detailed reply, Tronhard. Now I need to obtain the SD card reader suitable for my Dell Inspiron desktop.
02-11-2024 11:53 AM
Any branded USB card reader should do. Just make sure the USB reader cable matches the port on your computer.
02-11-2024 11:56 AM
Dell Inspiron 3880 desktop to be more precise, purchased in January 2021.
02-11-2024 12:03 PM
Yup, Tronhard, that is exactly how my Dell Inspiron looks in front. Thanks!!! Is your name as Scandinavian as it sounds? I'm of mixed Norwegian and Finnish ancestry myself.
02-11-2024 12:06 PM
Glad you have found a solution. Nope, I'm of UK origin, but my handle is a portmanteau of my first and last names.
