G5 LCD display works but doesn’t show photo image
fwrightson
I can not figure out how to make my Powershot G5 show either the viewfinder image or the photo just Aiken image. Any suggestions would be appreciated
12 REPLIES 12
fwrightson
I'll add that I'm in Replay and that I reformated the card and tried thaking another photo. The view finder image will not display on the LCD nor will will the image display after taking another photo. I even changed the display time time from the default 2 sec to 5 sec. The LCD displays the menus, etc for an image it only has a little blank retancgle.
Is this a new or used camera?  Did it everr work?
Are you formatting the card in the camera?
What is the brand and exact model of the card?  Is it full size or micro with an adapter?
Show us an image of the "rectangle"
fwrightson
Thank you for your reply. Actually, it was my late brother-in-law’s but he gave it to me before he passed. Yes, it did work (when he had it). I’ve had it for 18 months and just charged it up and tried using it.
I reformatted the memory card in the camera. It says it has 121 MB with zero used (before the reformat, it said 1.2 MB was used). It’s a PQI 128 MB Compacr Flash
Displaying photos after you take them is an option that can be disabled.  Many people disable it because it is an extra drain on the battery.  I recommend resetting the camera back to factory defaults, so that its configuration is in a known state.
Mark35mmF2
Hi there,
If you ppoint the camera at something and take a picture, can you then put your memory card in the computer and see that picture or is the new piture also a black screen?
Good question. While I have a USB card reader, it reads everything except the large FlashCards...howerver, I just.ordered a FlashCard reader, which will be here Tuesday...then I can answer your question. Since the flashcard is only 128 MB, I also ordered a 32 GB flashcard (I'm probably spending more than the camera is worth).
Thanks. I assume the rest to factory settings is on the menus option. I'll have a look and try it. Thanks again.
I received my new flashcard reader today. It appears that the card is properly formated and ok. There are three images on the card (with an image size of 125kb - which I think indicates no real image). I've taken some screenshots of what I see.
Screen Shot 2021-06-30 at 4.10.05 PM.pngScreen Shot 2021-06-30 at 4.10.53 PM.png
Below I have posted screenshots of the images. The FlashCard has three images so the camera thinks it is taking a photo but it looks as if no image is recorded (all black) when the shutter snaps. Entirely possible i guess.
