09-26-2018 07:42 PM
I have a Canon Power Shot A800 and a PS A1400. I carry the A800 around in my pocket for daily use and I also use both cameras for digiscoping. (A bracket holds the camera over the eyepiece of one of my telescopes.) Both cameras have dirt in the lens mechanism which may or not show up depending on zoom and/or focus. The first two pics are from the A1400. (The blur is movement from pressing the shutter. Did the dirt come from carrying the camera around in my pocket? Can I clean these myself?
The last pic was taken by the A800 at full zoom.
Perhaps I will be able to compose my next post more professionally. 🙂
09-26-2018 07:56 PM
I'm not sure how they both got dirty, perhaps your pocket did it to one somehow? Even if you could take them apart, then take the lens assembly apart to clean it you would not be able to put it back together correctly without the expensive alignment tools etc. to get the lens back together and working correctly. To get them serviced and cleaned would cost more than they are worth or very close. If you like those models look for working used/refurbished ones and get yourself a belt case or one of those fanny pack cases instead of the pocket. Maybe I'm wrong and someone else will chime in with a less dismal reply...but I think your cameras are toast now, so sorry.
10-04-2018 09:07 PM
09-26-2018 07:56 PM
09-26-2018 08:12 PM
Thanks, John. I suspected as much. I have a PS ELPH 180 on the way. It has (looks like) glass over the lens instead of the thin metal iris type protection of the A models. No belt opportunity, cargo pants and suspenders. 🙂
09-29-2018 10:04 PM
An alternative would be to get an all-condition camera like the Canon D30 - basically it is an underwater camera, so it it sealed and it is designed to take rough handling. If you decide to go for a camera like that I would have a look at DPRIEW's site and see their review of tough cameras.
10-04-2018 09:07 PM
