03-02-2018 01:53 AM
Hello,
I purchased a used Powershot SX530 and love it, but when I upload images from the sd card in Windows 10 they randomly appear rotated 90 degrees. The images are all taken in landscape view, but come rotated in portrait. I tried turning off AUTO-ROTATE but it still happens!! PLEASE HELP!
Thank you
03-03-2018 08:07 AM
Keep the auto rotate " on " position. Try taking portrait shots.
If this will not work, reset the camera from tools menu.
In windows 10 you can rotate images.
03-09-2018 05:30 AM
This seemed to happen mostly when the camera was pointed down at the floor. Could this be a bad orientation sensor?
03-09-2018 08:01 AM
In shooting mode at menu go to review image after shooting and set to 2 sec. Try shooting downward, you will see if really the image is rotated right away after shooting. If it is rotated then it is the software malfunction and it needs reinstall/updating. The sensor has nothing to do because it is fixed.
03-11-2018 01:55 AM
03-11-2018 08:40 AM
Go to menu select camera tab select IS ( image stability ) select shoot only.
Also try in AV mode, Scn mode, maybe a quick movement/shake of camera affect the stability.
Point the camera upward then quickly point downward and shoot any object - see the LCD if the image is rotated.
Try also the video in shaking hand fashion and point to any angle quickly. If video is shaking instably - from menu select continues image stablilization.
