12-19-2022
01:02 PM
09:52 AM
I have the EOS Rebel T7. I bought the SanDisk SDXC UHS-I Card. When I try to format I get message Cannot format change card. Change card to what?
Thank you,
KellyG
12-19-2022 05:47 PM - edited 12-19-2022 08:25 PM
256 GB, you say? That is much too large for this camera. I had not noticed that you had written SDXC, not SDHC. The Class I part is fine. It is the “XC”, for extended capacity, instead of “HC”, for high capacity, that is the issue.
I know the camera specifications say that the SDXC card should work. I get that. In the real world, the SDXC cards do not work. This is speaking from personal experience,, as well as the combined experiences of other forum users with the T5, T6, and T7 models.
You need to dial down card storage capacity to [UHS-I] I, SDHC, which is 32 GB or smaller, and I can almost guarantee you that all of your issues will go away.
12-19-2022 01:35 PM
@KellyG wrote:I have the EOS Rebel T7. I bought the SanDisk SDXC UHS-I Card. When I try to format I get message Cannot format change card. Change card to what?
Thank you,
KellyG
I think the reply “change card” is telling you to try a different SD card.
What brand of card do you have? Where did you buy the SD card?
Do you have a full size SD card, or a micro-SD card with an adapter?
12-19-2022 01:57 PM
Thank you for your response! It is SanDisk brand. I bought it through our company procurement system. It is full size: SanDisk 256GB Ultra SDXC UHS-I Memory Card - 120MB/s, C10, U1, Full HD, SD Card - SDSDUN4-256G-GN6IN
12-19-2022 07:06 PM
Is Error 02 what you are seeing?
Sometimes a brand new card needs to formatted in a PC first, and then formatted in camera.
01-04-2023 03:22 PM
Thank you again so much. I will try a smaller capacity card.
01-04-2023 03:23 PM
Thank you for your response! I tried formatting in PC first and it still would not work. I'll try another card.
