03-06-2013 06:28 PM
03-11-2013 04:52 PM
Hi Hashy666,
The PowerShot SX50 HS does not have a terminal that will connect to an external microphone.
10-04-2019 02:30 PM
To confirm, will connecting a label mic to an SX50 HS via a 5 pin Mini USB Male/3.5mm Female cable work or not?
Thanks.
10-04-2019 07:27 PM
@ayberry wrote:To confirm, will connecting a label mic to an SX50 HS via a 5 pin Mini USB Male/3.5mm Female cable work or not?
Thanks.
Probably not.
10-04-2019 07:42 PM
That USB idea will not work and could damage your camera. If that was possible Canon would have mentioned it in the manual but the manual only addresses the built-in mics. I would not try it you may wind up with a camera-shaped paperweight.
10-04-2019 09:28 PM
10-04-2019 09:31 PM
You're welcome!
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
