05-02-2014 05:10 PM
How can I download photos to folder named as such: 2014_05_02 with photos inside for that day only. My file shows as year only 2014 and inside 04 or 05 representing month.
05-02-2014 10:08 PM
If you are using the Canon Utilities Camera Window DC, you will need to click on the gear icon (preferences) in the upper right. After that opens, selelct the Folder Settings tab, and check the appropriate item under the create subfolder section. For the format you want, the first option should be fine.
05-02-2014 06:48 PM
what program are you using to download your image? and what OS?
05-02-2014 07:35 PM
And Im curious as to what model camera also?
05-03-2014 11:20 AM
Camera is Power Shot SX 230 HS
05-03-2014 11:19 AM
Camera is canon power shot sx230 & I use the software that came with it. Don't know what OS is
05-03-2014 12:09 PM
OS is your computer operating system, such as Windows 7.
05-02-2014 10:08 PM
05-03-2014 03:54 PM
That worked! After clicking gear icon I had to click "import" and then folder settings. The tech support for canon told me it was a computer issue not the camera. Thank you so much.
