Reply
Occasional Contributor
Accepted Solution
ix6820 Photo Borders Uneven
Hi all...  when I print out an image the white borders around the print are uneven... wider on one side and bottom.  I am using this printer for the first time.  Its all set up to my desired specs.  The window on the left that shows the image in the printing frame has uneven borders as well.  Here is a screen shot below.  I wonder if this can be changed... I've looked everywhere in the settings.  Hope someone can help... and thanks in advance.
Reputable Contributor
Re: ix6820 Photo Borders Uneven
Your screen shot shows a setting for Position and Size. Have you tried clearing the "Center" check-box and manually entering border dimensions for the Top and Left borders? You may have to fudge the measurements slightly to reposition the image in it's "frame".
Hi Tiggerrr2018,
If clearing the "Center" check-box and manually entering border dimensions does not resolve the issue, please call us at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST. This way we can troubleshoot this issue in real time.
Gave them a call and a tech helped me to find the solution.. it was in the Photoshop settings...  never would have seen this without his help... again thanks for the number!
New Contributor
what was the photoshop setting you had to change?? i have this same issue?
powered by Lithium
