07-28-2020 01:58 PM
How do I remove this error code?
08-07-2020 02:26 PM
Hello.
The error that you described indicates that there is an internal hardware issue with the printer. Please try the following to see if we can resolve your issue:
1. Turn the printer off.
2. Unplug the power from the printer for at least 5-10 minutes.
3. While unplugged, remove any paper from the unit.
4. Double check for any obstructions found in the unit or paper paths.
5. If no obstructions are found, plug the power back in and turn the unit on to see if the error has cleared.
If the issue persists, the unit will require service for correction. If the unit has been purchased within one year, please contact our phone support group at 1-800-652-2666 for warranty options.
06-27-2022 09:23 AM
THIS DID NOT HELP.
01-30-2024 11:39 PM
Did not work for me and I can't find a service center to have it checked.
02-01-2024 02:06 PM
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
