07-16-2014 10:35 AM
I recently purchased a Selphy CP910. Once I got it set up, I put pictures on a flashdrive from my computer inserted into the port and they printed successfully. When I loaded new images on the flash drive, and inserted it into the port, it showed a busy symbol, then stated that I should check to make sure there were images on the Flashdrive. The images I put on the flashdrive were directly down loaded form my Nikon Camera onto my computer. The same as the first batch I printed.
I then tried a different flashdrive and I got a Question mark. I tapped the Magnified glass + as suggested in the manual and this locked up the Selphy and I had to do a hard shut down to turn it off.
Any suggestions?
07-17-2014 11:55 AM
07-17-2014 12:04 PM
Yes it is FAT formatted.
07-30-2014 08:35 AM
No, it did not make a difference. I did however try again after letting the machine sit for a week ( I was away) this time the pictures showed up on the screen and I was able to print them. I am wondering if there is an issue with the thumbdrive port. I will call Technical Service as was suggested.
07-30-2014 05:52 AM
Hi lvnlife,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
