12-23-2012 03:26 PM - edited 12-23-2012 03:27 PM
Using a Canon Selphy CP900 and there appears to be a defect that if you edit the images in Photoshop, the Selphy doesn't recognize the images and refuses to display them on the screen or print them. Just a question mark is displayed. It does this to some images, but not all so I'm thinking it has something to do with the Exif data, but unsure.
There is something on the Canon Support page regarding this error, but no real solution to it.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/se...
Please advise.
03-29-2016 12:22 AM
03-29-2016 12:51 AM
06-05-2016 03:53 AM
I found a way around this...
Say You have a Photo that prints with selphy Example: PrintablePhoto.jpg
But you have a different photo that you edited, Got from the net, or made yourself Example: MyAwesomePhoto.jpg
Bring Both the copied PrintablePhoto(1).jpg and The MyAwesomePhoto.jpg Into a editing program
Now Resize MyAwesomePhoto.jpg to the same demetions as PrintablePhoto.jpg and Make your other changes Color correction or whatever you want to add to it. Then when MyAwesomephoto.jpg is how you want it right click it and select cut, now go to Printable image in the editor and right click paste. Now line it all up the way you want it and save PrintablePhoto(1).jpg you can rename it later.
The reason why this works is because printable photo has Information from your camera called Exif Data which is the date and time, Camera it was taken with, excetra But web photos and self created photos don't always have this type of data and so they wont be recognized. By putting the photo you want over one that prints in your photo editor your giving the file the same data as it had from the printable photo but its a different image your tricking it into thinking it was taken on the same day and your tricking it to think it was taken by your camera vs being created.
It still may give you a ? mine did before and after I changed the photo.
But the before photo showed ? and said Cannot Recognize Image
The photo after pasting it over the PrintablePhoto.jpg showed question mark but when I hit Print it printed out just fine.
10-03-2016 03:15 AM - last edited on 10-03-2016 08:38 AM by Danny
After much research..i found the absolute easiest fix to this very annoying problem. Go to the picture u r having problems with..open it in another program..i used "paint"....go to save as and change the name to "PrintablePhoto (1).jpg" If u are doing more than on at a time like me...u can use (2) ...(3) etc. Once u print it u can change the name to whatever u like. For me...i had to hit the + button to get the pic to appear once i haf my stick inserted in my printer. Sooo glad i finally got this to work. I was so frusterated. If u need more info or if i didn't mak this easy to understand..hit me uo [email address removed per forum guidelines]. Good Luck!!!
10-03-2016 03:17 AM
10-01-2018 04:05 PM
I have solved this issue by:
- Crop the photos to 4" x 6"
- Change image size to 4 inches by 6 inches with 300 dpi.
- Save images as JPG.
- Open the images with Paint and save as JPG again.
- Copy to your USB drive and enjoy printing.
I think because only the Paint App can support the EXIF properties.
By this way you can edit your photos as much as you can with Photoshop or any editor and print them while you are using Windows 10 or newer.
06-23-2022 11:44 AM
I found a Selphy CP800 printer in a thrift store - But then I had the annoying QUESTION MARK ERROR - after completing my image in Photoshop, it is 4X6 > 1440 px X 960px. Then I export it into a folder called "Selphy Images." I now open Lightroom and import images from my "Selphy Images." folder. Once I have selected the photos and begun to export, I change the file settings - Limit File Size to 50K and Width and Height to W:6 X H: 4. I know it is a process, but I got it to work. it worked for me.
