Scan Error Message
Sonshine
HI All
I have a MX454 which won't let me scan all of a sudden. It goes through the motions, but when it gets to the point of producting the scan for editing, I get an error message "An internal error has occured. Exiting this software". I have tried uninstalling and reinstalling, but stiil get the message. I run with Win8
Has anyone got a suggestion for me?
Thanks
2 REPLIES 2
tomw774
I'm having the same problem with my Canon MX922.  I could really use some help!
Thanks,
Tom
Patrick
Hi Sonshine,
There may be a program running in the background causing this error to occur.  Rebooting your computer without your normal startup applications running may resolve this issue.  To do this, follow the procedure below:
 1.  Place the cursor in the upper right hand corner of your screen to display the Charms Menu.
 2.  Click on Search.
 3.  Type MSCONFIG.
 4.  In the Search Results, click APPS and then click MSCONFIG in the results to the left.
 5.  The System Configuration Utility will appear.
 6.  Make a note of which startup selection your computer is set on.  If your startup selection is set to "Normal startup", switch it to "Selective startup" by placing the radio button dot next to "Selective startup".
 7.  Under Selective Startup, click to clear the Load Startup Items check box.
 8.  Click the Apply button.
 9.  Click on the Services tab at the top.
10.  Place a check mark next to 'Hide all Microsoft Services'.
11.  Click the Disable All button.
12.  Click Apply.
13.  Click the OK button.
14.  Windows will prompt you to restart your computer; click Restart.
When the computer restarts, please attempt to scan.
To return your computer to normal startup mode, follow steps 1-5 above, put a check in the box next to Load Startup Items, and then choose Normal Startup (if it was set this way initially) and click Apply.  Click on the Services tab and click on the Enable All button.  Click Apply, then OK and restart your computer.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Enter for a chance to win!
April 20th-28th
