Printer slow and hesitant
Shepherdboy
My ip7220 is very slow and hesitant, it will print one pass and 30 sec. later it will print another, I am trying to print an 8 1/4" square image on plain paper, it then ejects the paper with only 2" of the image printed. It has been recommended that I reduce the distance between the router and the printer. The printer worked perfectly until a week ago so I cannot see the distance has created the problem. Any ideas please, my hair is white enough.
Shepherdboy.
2 ACCEPTED SOLUTIONS
BillS
Mentor
Hi Shepherdboy,
Re-installing the drivers may also resolve the issue.  The most current drivers can be found at the Canon website HERE.  If you are using a Macintosh, deleting and re-adding the printer may also reduce printing time.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
I had re-installed the drivers several times but after your reply I removed the printer completely and re-installed it. It is now working as it should. Many thanks.
Shepherdboy
4 REPLIES 4
BillS
Mentor
Hi Shepherdboy,
Shepherdboy
vander
Such condition of the printer could waste time and test patience. I'm not good in trouble-shooting but you can check the settings first.
Shepherdboy
I would press the ‘Accept as Solution’ button if I could find it.
Shepherdboy
Enter for a chance to win!
April 20th-28th
