05-15-2019 12:46 PM - last edited on 05-16-2019 09:53 AM by Danny
CLeaned cartridge heads. I do have low ink, but prints 1st page fine. then 2nd page runs thru blank.
05-15-2019 12:58 PM
Hello!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your printer (USB or networked via WiFi or Ethernet).
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
05-15-2019 01:09 PM
i'm using a macOS, high sierra 10.13.6
connecting with USB.
After one page prints, get the 3 blink orange indicator of paper jam
05-17-2019 04:18 AM
Hi 4explore,
With the information provided, it appears the printer is reporting a paper jam after pulling the first page through. To troubleshoot this issue I recommend performing a visual inspection, two roller cleanings without paper, and one roller cleaning with paper.
When performing the visual inspection, unplug the printer from the power outlet of the printer. Uss a flashlight to inspect the rear tray and internal compartment for foreign objects/debris. If foreign objects/debris is found, slowly and carefully remove it from the unit. After performing the visual inspection, next perform the roller cleaning process. Click HERE for information on the roller cleaning process.
