12-08-2019 12:01 PM
When I press the power button the green light comes on, it briefly blinks once and then everything goes dead - there are no noises and no further lights come on and obviously no printing. Can anyone suggest how I deal witht his? Thanks, David
12-12-2019 04:45 PM
Thanks Darius, I have tried your suggestion and unfortunately it has not solved the problem. At switch, on the light blinks green once, then the printer goes dead until it has been switched off for a long time, when it will again blink once if switched on. I guess as you say its a question of a new printer. Thanks anyway, David
12-09-2019 04:14 PM
Hi DH371.
If the iP90 is not powering on correctly, try the following:
If the printer still doesn't power on, then it will need to be replaced. You are eligible for the Canon Upgrade Program, a one-time discount on the purchase of a replacement printer directly through Canon U.S.A., and comes with free ground shipping. If you're interested, you may call one of our phone-based Canon Direct agents at (866) 443-8002. Let the agent know you were offered the Canon Upgrade Program.
12-12-2019 04:45 PM
02-03-2021 03:50 PM
02-03-2021 04:12 PM
Hi Berty, I never did get a solution to this problem. A shame as it was a very convenient, portable printer, and I have
a stock of unused ink cartrudges ! Cheers, David
02-03-2021 04:19 PM
