06-07-2016 12:11 PM - last edited on 10-18-2023 08:19 AM by Danny
06-17-2019 10:21 PM
I'm having the same problem with my MG7720 printer. It suddenly started after cleaning print heads. I followed instructions for manually aligning print heads, but it didn't fix the issue. The suggestion to set paper to photo paper also didn't fix the issue for me. Double characters and alternating lines displaying from sharp to blurry now render this printer entirely unusable. Only black ink is affected, as others have reported as well.
06-26-2019 07:16 AM
I am having exact same problem with my cannon MX925, been great til now - wish there was a solution!
06-28-2019 01:09 PM - edited 06-28-2019 02:17 PM
Exact the same problem !!
Please help me !!
07-29-2019 06:29 PM
Same here... I've tried for over a year to figure it out on wi-fi MX 922. Trying suggestions that don't work. Frustrated.
07-29-2019 06:57 PM
Obviously, Canon is keeping a deaf ear on this subject and refuses to offer a solution or adequate offer. So much for customer support. MY solution: get an HP or a Brother and ditch Canon. Forever. Printers are not that expensive. It just bugs me that I just went out and puurchased 3 new sets of ink for the Canon printer, which are now useless.
08-02-2019 04:25 PM
Hello,
OMG I did it.
Sorry for my english.
My printer works much better now.
Sorry- it's in Czech languague.
You have to set up printer head MANUALLY !!!
Go to printer settings and something like "maintenance". ETC as per pictures. Let me know, if it helps.
08-03-2019 09:09 AM
Manual alignment works for some people, however it doesn't work in all cases. In my case, some of the settings are +5 but the alignment is still out. They would probably need to be +10 but you can't enter values that high and so the head never aligns.
07-20-2019 01:52 PM
Same problem here. If I can't find a solution, will ditch the printer and go with one from HP.
08-03-2019 09:14 AM - edited 08-03-2019 09:14 AM
Where is Canon's response to this problem??? Has anyone heard from them about this?
08-03-2019 09:51 PM
All attempts by myself so far to get Canon to acknowledge that this is a common fault and investigate it further have failed.
Canon simply direct consumers to their repair centres to 'evaluate' the problem at the consumer's cost and the repair centres recommend printer replacement because replacement parts would exceed the cost of a new printer.
