07-04-2014 10:26 AM
I cleaned and deep-cleaned the heads. I doubt it's a software issue or it would have copied fine, no?
The test page printed fine, with all colors present, etc.
07-28-2014 01:56 PM
Hi Lopato,
In regards to this issue, it would be faster to contact us. Before you do though, please verify that the test page that you printed is correct. Please follow these steps:
1. Press <HOME>.
2. Rotate the menu to Settings and press <OK>.
3. Press <OK> on Maintenance.
4. Press <OK> on Nozzle Check Pattern.
5. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached below:
For further assistance, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
