Reply
New Contributor
MG3100 not recognizing new ink
My colored ink was low and everything was printing pink. I bought new ink and replaced it but my printer isn't recognizing that I have new ink and is still printing everything pink as if I hadn't ever changed the ink. I've tried reseting it and turning it off and taking the ink out and putting it back in and I can't get it to work! I have confirmed that there is actually ink in the new cartridge I put in.
Re: MG3100 not recognizing new ink
Hi Kelsey88,
This issue may occur if the ink cartridges are replaced prior to the ink being completely empty.  We recommend only replacing the ink when it shows the ink is completely empty.  If the ink is replaced too soon, it will not register the fact that a new ink has been installed.
If you happen to have an ink cartridge that is actually empty, you may be able to put it in the printer so it recognizes the empty cartridge and provides the ink cartridge empty warning.  You can then replace it with the new ink cartridge and the printer will determine that it was replaced and provide a full ink level indication again.
If non-Canon genuine ink cartridges are being used in the printer, or if the ink cartridges have been refilled, the printer may not recognize the ink levels properly.  Replacing the ink with Canon genuine ink cartridges may resolve the issue if third-party or refilled Canon ink cartridges have been used.
Hope this helps!
New Contributor
Ramona,
It was definitely empty enough that it needed to be replaced. Whenever I printed something on my computer, it popped up and told me the ink was low and needed to be replaced. When I tried to print anyway, I could not print anything in color because everything was printing in pink, (as I said in my post) and that made it impossible to read. If it had to be completely empty of every color, that is a definite design flaw with the printer... because it's not acceptable to print everything in pink until the red runs out too.
I replaced the ink with Canon ink so that was also not the problem.
-Kelsey
New Contributor
[ Edited ]
I am having the same problems! I read the manual to go to the maintance screen and to choose to continue printing even when low or change the color.... but I went to the maintance screen and I only saw the option to continue printing only on color or only in black. I am not got to pay another 50 bucks to get new ink
Hello.
If the error still persists and new, genuine Canon ink cartridges have been installed, additional troubleshooting may be needed.
Please visit the following link below to contact our support group for additional assistance.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
New Contributor
That is just dumb.  I bought new ink as my ink cartridges were low and one of them was not printing.  The new cartridges have ink but the ink has always been noted as low.  Who the hell thought up how this works?  To me this is just a stupid DRM put on paying consumers.
What the hell Canon!
-disgruntled owner of a canon printer who will just buy a new printer instead of getting more canon ink!
Highlighted
New Contributor
What a disgrace that Canon operates this way. It is such a waste of my time and money. Do they expect we will endorse the product and recommend it to others?
New Contributor
Click and hold the stop/reset button for about 10 seconds. The blinking light and error will stop and you can print again.
New Contributor
I do Computer Repair for the Passaic County, Bergen County, and Morris County areas of NJ and we run into Printer problems all the time. Read my article below. I hope it helps.
http://1fixcomputermedic.com/Blog/2015-07-14-printer-ink.html
New Contributor
Thank you thank you thank you. I had been pressing that button, and finding it did nothign for me. Holding it down for 10 seconds did the trick. I am so grateful!
powered by Lithium
