05-02-2016 10:00 AM
Are there lists of which models use which cartridges anywhere?
I'm interested in replacing a older "i" series with a used printer only (no all-in-one).
05-04-2016 10:06 AM - last edited on 05-04-2016 10:24 AM by Danny
Hi videobruce,
The PIXMA iP series printers replaced the i-series printers.
The PIXMA iP series line are printers only, they do no have the ability to scan or fax.
None of the printers currently available are supported with the Linux operating system.
05-02-2016 10:08 AM
Hi, videobruce!
So that the Community can help you better, we will need to know either which ink cartridges you have, or which printers you own or plan on getting. That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/ContactCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
05-02-2016 11:23 AM
Thanks for the quick reply.
I don't know what printer since there are so many models and I don't know the differences between the different cartridges regading refilling with bulk ink which is my main concern.
I was looking for a list of printers each cartridge can be used with.
05-04-2016 08:53 AM
Hi videobruce,
The MP/MG model printers offer print, scan and copy capability, and the MX model printers offer those same functions, as well as faxing capability. The single function printers that we currently offer can be viewed on the Canon USA website here.
We don't recommend the use of refilled or remanufactured inks in our printers, and cannot guarantee that they will work with our printers. Our print head and inks work together as a precisely engineered system to support optimum image quality, print speed and reliability in higher resolution text and color printing applications. If you have difficulty locating inks for your printer locally, you can purchase Canon supplies and accessories at the Canon eStore here.
If you are unsure of the printer model that you have, we ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) and a Canon technical support representative will be happy to assist you with determining the model, and also be able to provide you with information on other printers that use the same type of inks. There is no charge for this call.
05-04-2016 09:22 AM - edited 05-04-2016 09:23 AM
The "ip" series came out after the "i" series and replaced them. Correct?
Are the "ip" series the only ones that are just 'printers'??
Also, are any of these compatable with Linux?
Hi videobruce,
05-04-2016 10:26 AM - edited 05-04-2016 10:27 AM
Thanks for that.
Why is Canon so anti-Linux??
05-02-2016 10:03 AM
I'm looking for a non all-in-one, 4 or maybe 5 color printer only. I see all now are AIO which I don't want or need.
The apparent older "ip" series, are those the only printer only models? Are all the "MP/MG/MX" model numbers multi function?
