Reply
Highlighted
New Contributor
IP7250 print head error
My IP7250 has suddenly started reporting a print head error, is there anything I can do to fix it or do I need to replace the print head?
Thanks
Highlighted
Moderator
Re: IP7250 print head error
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, to go: https://global.canon and select your country or region for your support needs.
Highlighted
New Contributor
I would if you had a UK forum!
Highlighted
New Contributor
Anyone?
Highlighted
Occasional Contributor
[ Edited ]
Moderator:  my third message on this board here.  Three people over past 3 days having exact same problem 3 different Canon printers.  Print Head Installed on printer not correct one.  that's first message I got.  How could I have the wrong one?  Did you have a recent s/w update that put the wrong update on our printers?  Either that or we all have pretty lousy printers that the print head collapsed basically at the same time for all of us.
Just found this later on in this series of messages:  So if the print head is actually damaged, and you buy a new one for your device if it's an MG series, this is where to go to find out how to change it.  Doesn't seem difficult but I wonder about so many lately getting a damaged print head error.
Please follow the steps outlined in the following Knowledgebase Article to remove the printhead from your PIXMA iP7220:
https://support.usa.canon.com/kb/index?page=content&id=ART142045
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
Highlighted
unfortunately print cartridges are stuck on left side and in this way the instructions did not match what I could see.  When I pulled down a door in front, it appears to be to print dvd/cds.
powered by Lithium
