10-25-2014 12:11 PM
10-28-2014 07:11 AM
Hi wriley3,
To try and resolve the issue, with a flashlight or other bright light, please check the paper feed area of the printer and verify that there are no paper jams or obstructions in the printer that may be causing the error. Once this has been done, please look inside of the printer where the inks are located and ensure that there are no obstructions in there that may be causing the print head not to move freely. Next, please remove and reseat all of the ink cartridges in the printer.
If you still experience the same error after following the instructions above, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the error persists, the unit will require servicing to resolve the issue. Please call or email us at one of the methods on the Contact Us page to obtain your servicing options.
10-28-2014 07:11 AM
Hi wriley3,
